Thread: Mice...
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Mice...
    My heat pump was not working, called a tech in he found the problem, a mouse had chewed the insulation off some wires, then a lizard was found fried laying across those bare wires....I live by a lake, a person at home depot told me to use minced garlic around were the mice were found, I had one that chewed through my bird cage, I put the garlice around the bottom, haven't seen any mice....strange things happen.
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    May 2014
    Worcester, MA
    29
    Re: Mice...
    That'll work fine unless you get some Italian mice, then you're screwed!
    John
    IG 33K Gallons 20'X40', Hayward Pro Series Sand Filter S310T2 (zeolite), Pentair Intelliflo 3HP SVRS Pump
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Mice...
    Oh ya I would be....
    Autopilot SWG
    Sep 2015
    Tucson AZ
    1
    Re: Mice...
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    I have no further problems with dead rodents in my pool since placing a string of Christmas lights completely around the pool, which is activated by a dusk/dawn timer. The only time I found another mouse was when a power failure turned off the switch overnight. IT WORKS !!!
