Thread: this bleach or that chlorine
    Jul 2012
    Whidbey Island, WA
    397
    So am using 128oz jugs of 5.25% bleach from local hardware, $2.50 per jug
    InTheSwim has one pound bottles of Instant Liquid Chlorine (a powder) for $5 per
    would be fun to have fewer empty bleach bottles to recycle
    would Instant Liquid Chlorine be Ok alternative?
    ooops, I found on TFP web regarding the stuff
    More smoke, mirrors, and misdirection. You can see the manual/info sheet here, and its 73% Cal-Hypo.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: this bleach or that chlorine
    Quote Originally Posted by engrav View Post
    That is cal-hypo which will increase your CH which could lead to calcium scaling.
    http://www.troublefreepool.com/conte...alcium-scaling
    All solid forms of chlorine adds something that stays in the pool after the chorine is used up.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    That's 73% Cal-hypo.
    If you have low CH, it can be viable. If you have normal or high CH, you're begging for CH buildup and scale formation. http://www.troublefreepool.com/conte...nate-your-pool
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    no instant liquid chlorine
    have now found 10% and 12.5% which will cut bottles over half
