Thread: Intellichem with Liquid Chlorine Tank
    Jul 2014
    Sacramento, CA
    7
    We're planning on starting our pool build in the coming month. TFP has provided a wealth of information for a first time pool owner and has been my go to resource. Most of the pool builders in our area are recommending we stay away from chlorinating our pool with a salt water generator for various reasons. Instead, most are recommending Trichlor pucks using a Rainbow Automatic Feeder. Thanks to TFP, I'm terrified of the potential CYA issues when using Trichlor pucks and want a viable alternative. Has anyone used the Pentair Intellichem with a liquid chlorine tank to automate chlorine addition to their pool?
    25k IG Pool and Spa (Under Construction)
    Pentair Easy Touch 8, Intelliflow VS, Clean & Clear Plus 520, Racer w/ Boost Rite, Intellichem, Sta-Rite 400 Heater
    Blue Granite Pebble Sheen
    Jul 2014
    Sacramento, CA
    7
    Re: I'm looking at the IntelliChem
    Any other thoughts on the Intellichem and its use as a liquid chlorine and acid dosing system for an lower CYA level pool? We're starting our pool build and am thinking about adding it to our equipment list. Any feedback would be greatly appreciated.
    Re: Intellichem with Liquid Chlorine Tank
    A liquid chlorine tank is fine. You can control it with a timer, and get very good results. A fair number of people use systems like that.
    The IntelliChem depends on an ORP sensor. ORP sensors sense many thing, not just chlorine. As a result the ORP reading does not reliably indicate the FC level. The sensors also add significant expense and bring a host of reliability issues. A simple timer will give you better results, for less money, and with far fewer reliability issues.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum soon to be new pool owner
    What were the reasons you were given against going with a SWG ??
    Maybe you can add some info on the pool and proposed equip ?? http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 76
    Jul 2014
    Sacramento, CA
    7
    Thanks for the replies. Regarding a SWG, I'm not a huge fan of having to change to liquid chlorine when the temperature drops below 60 degrees. This seems to be two solutions for the problem while automating liquid chlorine doses is a year-round solution. We also will have some natural stone coping with our new pool build. While the stone we will choose is not a softer sandstone/flagstone, I'd prefer the peace of mind that we won't have to worry about any pitting or corrosion around the pool.
