Thread: Any way to bring water temps back down?
    My water temperatures have climbed into the 90s and it's too warm to really enjoy the pool. Is there any way to bring the temperature back down?
    10,500 gal inground pool with vinyl liner. sand filter, TF100 test kit.
    Jun 2014
    Houston
    110
    Re: Any way to bring water temps back down?
    Quote Originally Posted by Granny View Post
    Aeration at night.
    Basically set up a line from one of more returns that comes up out of the water and sprays the return water back into your pool. Kind of like a showerhead.
    30 year old, 17,000 gallon pool (w/spa), IG, Plaster, Pentair Triton II TR-100 600#Sand Filter, Pentair Superflo 340043 1.5 Hp pump
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    You can make your own or buy a fountain head that connects to one of your pool returns. It sprays a fountain of water into the pool. My temp was at 94 last Friday. I ran it overnight as we had lows in the low 70's and by morning our water was at 84 degrees.
    This is is a link to the one I bought at a local pool store. Keep an eye on your PH as it will rise from all the aeration.
    http://www.ebay.com/itm/Flower-Fount...-/140734677913
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To give good advice we really need you to fill in your location in your profile: http://www.troublefreepool.com/conte...etting-started as effectiveness of various cooling techniques will partly depend on your climate
    Thanks you two, I appreciate it.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Where I live that's one thing I will never have to worry about!! But my heater has a chilling feature. Go figure.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
