Thread: Low Cyanuric Acid Levels
    Jun 2014
    Queenstown, MD
    25
    The pool fill is just a week old now. pH has been consistently 7.8 to 7.4 over the week. Alkalinity is 80. I add 30-40 oz of 6% bleach daily to obtain 4 ppm FC. The FC tests at 1 to 1.5 just before adding the bleach.
    I added 35 oz dry condition in a sock starting as the pool fill started. It has been fully dissolved for 3 days now. I just tested for cyanuric acid and it tests off the scale. It is close at 30 ppm but I can still see the black dot when the small vial is full (Taylor K-2006 test kit). Does it take more time for CYA levels to be testable? Or do I need more CYA to get to 40?
    10000 IG plaster pool / Pentair Clean & Clear Plus 420 sqqft cartridge filter / Aqua Rite SWG T-15/ Taylor K-2006 Test Kit
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Low Cyanuric Acid Levels
    I had that same problem after adding stabilizer, took about a week to drop to normal..
    Sorry misunderstood...your to low...not high...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    38,346
    We recommend waiting a week after the cya dissolves to test it. Just assume it is at the level you targeted until then.
    Jun 2014
    Queenstown, MD
    25
    Ok, thank you for the input. Its only been a few days since it all has dissolved out of the sock.
