Results 1 to 10 of 10
Thread: New guy from Indiana
    Jul 2008
    SW Indiana
    13
    Hi everyone,
    Just wanted to let you guys know that I love your forums.
    I am not a pool owner as of yet but we are getting close. The builder is coming out Saturday to give us a quote on a BG 20x40 vinyl. I hope to become a lifetime member if this all pans out.
    I have already learned much about pools on this site and I am sure the learning will never end.
    I do have a question. The guys that is giving us a quote has put in a pool for one of my friends. It looks very nice. At the corners the liner is not flat to the metal framing. It is tight but you can push the liner and it has a spring to it. Is this normal?
    Don
    Bonita Springs, FL
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: New guy from Indiana
    Welcome from another Indiana resident.
    Are you talking about the liner at the top or below the water line? It should be tight to the surface below the water line, but above the water line there may be a little gap between the wall and the liner at the corners.
    Jul 2008
    SW Indiana
    13
    Thanks JohnT
    I was talking about above the water line. That answered my question. TFP ROCKS
    I am in SW Indiana also. Ever heard of Elberfeld? It's about 15 mile north of Evansville.
    Don
    Bonita Springs, FL
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    As John said, it's normal for the liner not to be on the wall in the corners above the waterline and for a couple of inches below it. Liners need to stretch into the pool or you'd end up with wrinkles , therefore they are made slightly smaller than the pool - -how much stretch you'll get out of a new liner is dependent upon the heat and sun exposure when you install the liner. That's why on 2 identical pools with identical liners, 1 will have the corners fit 'snug' and the other will have the gap you're talking about (the 'snug' one was installed on a warmer day or had full sun on it) The most important thing is not to have wrinkles!!
    Again, welcome here, if you have more questions as the pool is being built or when you finally get to swim in it, just ask us and we'll help you
    (I wish I could tell you my only Indiana experience - 1989 Dead show @ Deer Park, but this is a family site )
    Luv& Luk
    -Ted
    Jul 2008
    SW Indiana
    13
    Waste,
    Thanks for the great info. My friends pools was installed in the winter so that explains that. By the way, I have had some of those Deer Park days myself. 8)
    Don
    Bonita Springs, FL
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Polish Pounder,
    Welcome to the forum
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome I "heart" Indiana!
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Welcome from Jeffersonville, Indiana! You won't regret finding this website, its awsome!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    Mar 2007
    4,160
    Quote Originally Posted by Polish Pounder
    Waste,
    I hope that wasn't your wife or girlfriend :P 8)
    Luv& Luk
    -Ted
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Glad you found us and are enjoying the site.
    By getting started off right, you are going to save yourself lots of potential headaches.
    Welcome!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
