Results 1 to 8 of 8
Thread: Water flow slower - where should I start?
    Jul 2011
    Northern MN
    21
    Hi all,
    The water from my return is coming out noticeably slower this year than previous years. Not sure where I should start to try to diagnose and fix the issue.
    A few more clues: When I backflush the filter, the flow there is slower as well (so I presume it probably isn't my return line). I am getting a few occasional air bubbles coming up from the return stream. The pump seems and sounds to be running fine.
    Any suggestions where to start?
    Thanks in advance!
    Rob
    24-ft round Radiant AG, fully in the ground, 14,500 gal
    Sand filter, 1.5 HP pump, vinyl liner
    9 months of winter, 3 months of tough skating!
    38,242
    Re: Water flow slower - where should I start?
    Bubbles in pump basket would indicate a suction side leak. Could be a clog in the impeller reducing flow.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd start by checking that all the valves are positioned correctly and that all the winterizing plugs are removed. And then I'd start looking for an air leak. By the way, what is the pressure compared to previous years?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also check and lubricate the pump gaskets on the plugs and the basket seal with silicone or teflon lubricant, don't use petroleum jelly as it makes the seals expand.
    Jul 2011
    Northern MN
    21
    Thanks for the ideas, guys. I'll pull the filter and check it for clogs and gasket issues. Then look into how to find air leaks. Bubbles are very minimal, FYI, and the pad is dry around the pump and filter.
    FYI the pressure on the filter gauge does seem rather low compared to last year. However, that info is closed by the fact that for some reason my gauge, which was new last year and removed for winter, now has a zero-pressure (uninstalled) reading of 30 psi. I presumed I only cared about the pressure delta between a clean and dirty filter, and that the gauge was still operating ok for that purpose, but maybe I should go get another gauge.
    May 2014
    Sutton, MA
    14
    This might sound simple, but check the skimmer. Mine sometimes gets stuck in the up position, letting in air, and decreasing presume.
    38,242
    You need a new gauge. Get a better liquid filled one like the ones tftestkits now sells.
    Jul 2011
    Northern MN
    21
    Thanks again, everybody. Brief update: the problem was a clogged impeller. Easy enough to clear up. Hardest part was unhooking the hoses and hooking them back up. 2 screws, remove the basket, and boom a big wad of leaf debris. And now flow is WAY improved. Yay! Also the off-vs.-on pressure delta is what it has been in previous years, so that's a good sign - though I'll look into that new gauge too! I also cleaned and lubed the gaskets while I was at it.
    One more question: I only cleaned the "front" side of the impeller and didn't remove the larger circular housing around it (because I was late for work and it didn't come right off easily when I removed the eight screws). I haven't researched either the manual or the pool school to see if I should check that area for debris too. Should I?
    Funny how exciting it can be to just get things back to normal!
