Thread: Help with Conditioner
    We recently got our pool refinished and we are trying to get everything balanced. Leslie's told us to put conditioner in our pool so our chlorine would stay active longer. We accidentally threw it all directly in the pool rather than dissolving it or putting it in a sock in our skimmer. Now, we can see all the granules sitting on the bottom of our pool. Will this cause damage to our new surface (I think it's called sunstone or something like that)? Should we try to vacuum it up with the aquabot? Or vacuum it with the normal vacuum that will go to our filter? Or, just leave it and wait for it to dissolve? Thanks for any help!
    40,000 gallon inground gunite pool, Sand Filter, Teel Pump 4RJ95 3450 RPM 2HP. Royal Oak, Michigan
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Help with Conditioner
    vacuum it into the filter and leave the filter run overnight. It is acidic and can cause freckles in the new surface.
