Thread: Chlorinating
    Jul 2014
    Bullhead City/AZ
    9
    Chlorinating
    Got my CYA at about 50 and don't want to raise it any more. Want to stop using tablets. If I use liquid chlorine, do I have to add it by hand every day or so? Is there an auto chlorinator that will do it as needed?
    Built 3/14, 12.5K, .75 HP Stealth pump (2) 1 filter 1 popup clean sys, IG plaster, Jandy DE48 filter, Paramount O3 Ozinator, Nature2 purifier, 400K nat gas heat, pool master 5-way.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Chlorinating
    Yes, manually. Or do a search for liquidator or stenner pump.
    After a couple weeks of regular testing and dosing, you'll know your pool's personality and appetite, and will be able to guess your test results with amazing accuracy before you run the tests. It can get down to a couple minutes a day, if that, to dose the pool manually.
    Jul 2014
    Bullhead City/AZ
    9
    Re: Chlorinating
    Thanks so much, like the dentist analogy.
    Re: Chlorinating
    I cant be home everyday so what I do is get the chlorine above the max from the calculator, which mine is a 10.
    In the middle of summer like it is, I loose about 2-2.5 a day.
    So I can go from not adding chlorine for 2 days and still be fine.
    I usually add every other day.
    Jan 2012
    'burbs of Augusta, Georgia
    7,266
    Re: Chlorinating
    Salt water chlorine generator !
    May 2013
    Fort Lauderdale, FL
    423
    Re: Chlorinating
    Yes, SWG! Salt is the way to go. Makes it's own chlorine. Read up on it. There's also a SWG forum here. I converted and highly recommend it.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
