Results 1 to 7 of 7
Thread: Vinyl - Can I remove my drain?
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    Can I remove my drain cover so that I can attach a small section of 4x1.5" pipe so that my cleaner doesn't get stuck on top of the drain? I am not too familiar with the custruction of a vinyl pool to know if by removing that drain I will loose the seal between the liner and the pipe and thus begin to leak water.
    26k IG Vinyl, 2 HP single speed,24" Tagelus Sand, 1.5" pipe, 1 Main, 1 Skimmer, 2 jets, pool built 1983, new vinyl 2014, 36'x18', Deep End 8', The PoolCleaner 4X Suction.
    Pool Math #__# Pool School #__# Best Android App "Pool Pal" Track Your Levels!
    30,426
    Re: Vinyl - Can I remove my drain?
    I don't have a main drain but it is my guess you could be creating a problem by removing the cover.
    I would find another way to solve your issue but it would not include removing the cover, I don't think.
    mark-o's Avatar
    Jun 2014
    Bossier Louisiana
    18
    On my pool to remove the drain cover or "dome" you would also be removing the O-ring seal. Not gonna work if it's like all the others I've seen. Are you sure it's not the drain suction causing the problem? Maybe try closing the valve off a little more? Good luck.
    16 x 36 inground vinyl w/ covered steps. 9 1/2 ft deep end w/ diving board. 27,000 gal.
    PacFab Challenger 1 1/2 hp 2 speed pump, Pureflo 300 lb sand filter, Pentair chlorine feeder
    1 skimmer, 1 main drain, 3 return lines and NO LEAKS "knock on wood" LOL.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    I agree with the others. You dont want to remove that. The chances are high you will end up with a leak.
    Divin Dave,
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    Thank you every one. I have already closed the valve all the way simply to get enough suction to run the cleaner. I reckon I'll do it the old fashion way... Fins and googles and zip ties
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Your drain cover is designed to avoid entrapment, so don't change it. A Unibridge will keep the cleaner from getting stuck.
    xokeman's Avatar
    Jun 2013
    Memphis, TN
    72
    So I removed my drain and afixed two pieces of pipe only two screws retain the drain cover. Initially I had just the single piece of PVC attached as shown. The cleaner still climbed up on top of it. Thus the use of the second vertical.
    I think I like the idea of using a 4" cap cut down. I may have to be on the look out.
    This is what the pool looks like with the drain removed
