Results 1 to 14 of 14
Thread: Slamming pool, some questions?
    Jun 2012
    Jackson, NJ
    105
    My CYA is low at 20ppm so I wasn't in a rush to dump 4lbs of it into the pool just yet, but I was gone for about 3 hours and tested the water for CL and it ate up about 10+ ppm !?!?!! Where the faznaksy did it go??? Is it because my CYA is so low? I know I don't have that much **** in the water, it's crystal clear and has been I'm only slamming because I let it drop to 0 and saw some algae creepin on the walls (greenish tint in a few places). So that's the first question.
    Can I add borates (complete process) while I'm slamming? Overlap the whole thing, I already the 22 boxes of borax and 7 gallons of MA teehee. That's question número two.
    I/G Concrete w/spa 29k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Slamming pool, some questions?
    You will lose a whole lot to the sun without adequate CYA. If you have algae on the walls - enough to see - you have algae in the water, too. Maybe lurking behind lights, under ladder treads, anywhere and everywhere. That can eat chlorine up fast, too.
    10+ is not the kind of test results we like to see.... the recommended FAS-DPD test can accurately measure FC up to 50ppm. If you don't have the right test kit, you'll just be prolonging the SLAM and without the CC test, you'll never really know when you're done. End sermon.
    I wouldn't even think about borates until that pool has passed all three tests for ending the SLAM and everything else is balanced and stable for at least a week. Your sole job right now is to monitor FC & CC and brush that pool until it passes. Then you worry about raising CYA and adjusting pH and TA and all the rest. Lastly, you worry about borates. They're totally optional. I mean, seriously, it's like putting chrome tailpipes on a car with an audible misfire. Deal with the important stuff first!
    Jun 2012
    Jackson, NJ
    105
    Point taken!
    I have the TF100 XL kit
    To be specific I lost 12ppm in a span of 3 hours while I was at the store. I hVw been testing all day and adding CL, my CC has been at 0 the entire time, in fact I can remember the last time my CCs have been over 0.5.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    So leave CYA where it's at also? I have a lot of sun.
    DE
    Polaris 280
    Aqualink RS4
    Richard320's Avatar
    Jan 2010
    18,966
    No, you want to raise CYA, but not until after you pass the SLAM. If the CC is below .5 and the water is clear (that includes any patches on the walls) run the overnight loss test tonight. If you pass, hang the sock full of CYA in the pool as soon as you know.
    Jun 2012
    Jackson, NJ
    105
    Ok will update.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    OCLT this morning yielded 2.0ppm FC loss Water is and has been crystal clear CCs at less than 0.5
    What sucks is that Im now at work and wont be back til 5 so I will have my wife add some CL around lunch time and my son bruch the pool... and hope for the best.
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    So my fix has been at no less than 11ppm all day and I've been cruising it at around 13-15ppm since I came home. Brushed twice again.
    Starting my OCLT tonight with 13ppm as of now.
    DE
    Polaris 280
    Aqualink RS4
    38,235
    Good luck, fingers crossed
    Jun 2012
    Jackson, NJ
    105
    ****, OCLT yielded a loss of 1.5 ppm
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    This is so frustrating, last night yielded 2.0ppm loss overnight. The rain storm form yesteday didnt help.
    DE
    Polaris 280
    Aqualink RS4
    Butterfly's Avatar
    South Carolina
    10,045
    Keep SLAMing, you are close!
    You're done SLAMing when:
    Jun 2012
    Jackson, NJ
    105
    I was so close the other night and then I sort of dropped the ball with the rain storm
    DE
    Polaris 280
    Aqualink RS4
    Jun 2012
    Jackson, NJ
    105
    PASSED!!! Woot woot!!! pashents is works
    Now onto the CYA addition and Borates.
    DE
    Polaris 280
    Aqualink RS4
