Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: All is well, but a little cloudy
    Apr 2013
    NC
    65
    Hi everyone! We have been swimming away, and having lots of fun in our pool, and up till Friday, the pool looked good! It still looks good, just not as clear as it has been. I would call the water minimally clear-white-cloudy. Here are our readings from the pool store water test:
    FAC 4
    TAC. 4 (0.2 difference)
    CH. 50 (they say that's too low, but it's a vinyl lined pool)
    CYA. 60
    TA. 80
    pH. 7.4
    Copper. 0
    Iron. 0
    TDS. 300
    Phosphates. 300
    So, here's what we do daily - test water am and pm, then add about 2-4 cups of 8.25% bleach (depending on the day's weather and pool usage.). My husband brushes and vacuums the pool about every other day. Then, once a week (on Sunday) we brush the pool and add about 1 cup of algecide just for maintenance. We run the filter pump 12 hrs on, 12 off. Up till this weekend, that has worked. I didn't buy any chemicals at the pool store, wanted to check in here first.
    Any thoughts?
    ~ Green as algae, but willin' to learn! ~
    ~26' Intex Ultra Frame Pool - finally leveled!
    ~approx. 17,000 gal
    ~2,500gph pump w/ cart. filters~Taylor K-2005 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: All is well, but a little cloudy
    It's looking cloudy because the FC level is too low for the CYA level, if you believe those results. I don't, and there are countless threads here detailing massive discrepancies on water tests between stores and even between the same water at the same store on two different days, with CYA miraculously dropping overnight.
    My advice is to stop spending money on algaecide and invest the savings in a proper test kit.
    For the short term, try raising FC up to 10 or 12. That's well below shock level, so you won't lose any swim time, but it should help clear things up. A lot of swimmers will really deplete the chlorine.
    Apr 2013
    NC
    65
    Did you mean FC up to 10 or 12?
    Also, because the numbers were looking good, we went ahead and bought the salt water system. My husband is EXTREMELY anxious to put it on, but I'm wondering if we just install it, or if we need to do something special to make the switch.
    ~approx. 17,000 gal
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Make sure you take Richard's advice about the test kit and the algaecide. Wise words. And yes, I'm sure he meant 10, not 100.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Apr 2013
    NC
    65
    Hello all!
    Last night I added 138 oz of chlorine. Today I was able to purchase a Taylor K-2005 kit (long story, but, that's what I was able to get today, and the way my water looks, I didn't want to waste any time.). I hope having this kit instead of the TF-100 is ok, at least for now.
    I just got done testing the water and here are the numbers I got:
    FC. 5
    TC 5
    CC. 0 (I didn't see any difference in color)
    pH. 7.6
    TA. 90
    CH. 40
    CYA 90 (yikes!)
    The water looks teal and is not clear. I can see the bottom, but it's cloudy.
    According to pool math calculator, I need 121oz more chlorine and to dump 33% of my water. I'd like to see if any of you have other suggestions. Also, as a side note, my husband is in the process of adding salt for the SWG.
    Any info would be helpful. Thanks!
    ~approx. 17,000 gal
    Apr 2013
    NC
    65
    So, did putting Algecide in the pool put me on the do-not-call list? Sorry about that, I only used it because my parents have had an in-ground pool for many years and that's all I've known as far as one of the weekly maintenance chores. Anyway, hopefully I'm not on bad terms here, I've enjoyed being part of the forum and will continue to browse...
    ~approx. 17,000 gal
    Smykowski's Avatar
    Sep 2011
    3,065
    If the pool is properly chlorinated, you should never need algaecide again.
    The K-2005 will get you most of the way there, but it doesn't have the FAS-DPD chlorine test, which is critical when you need to maintain your FC above 5. I suggest you buy it as an add on.
    If you haven't spent any time in pool school yet, click on the link in my signature to get started.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    If you have the K-2005 the only thing you really need is the FAS-DPD chlorine test. Buy it before you think you'll need to check chlorine levels over 5 ppm.
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Apr 2013
    NC
    65
    Quote Originally Posted by Smykowski View Post
    Quote Originally Posted by freqz View Post
    Thanks...I'll have to get that extra test kit....sounds like I'm going to need it soon. I have spent lots of time on Pool School and lots of time on the forums. Up until this past Friday everything was good....the only thing I did against BBB (besides the algecide ) was not get the better kit before now (STUPID me!) I was relying on the pool store tests and test strips...somehow thinking that as long as I was following BBB, I'd be fine. So, I guess you could say I have been an educated dummy! Thanks again for the info!
    ~approx. 17,000 gal
    Apr 2013
    NC
    65
    Just thought of another question...With my CYA being up to 90. It has already take some serious chlorine to get my levels up, and it's going to take more to maintain that level till the pool clears. CYA doesn't deplete, right? If that's the case then shouldn't I dump my water now, then SLAM, before I go to all that expense of adding more chlorine?
    ~approx. 17,000 gal
    Smykowski's Avatar
    Sep 2011
    3,065
    All of that is correct. SLAMing is easiest with a CYA of 30. It can be done at 50-60, but will require much more chlorine.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Heather_A View Post
    You are correct Lower the CYA to something reasonable, like 60ish, then SLAM.
    You can adjust CYA back up (70 - 80) after the SLAM.
    Once the SLAM is complete, you should have smooth sailing with the SWG, once it is dialed in.
    You're done SLAMing when:
    Apr 2013
    NC
    65
    I'm going to double check the CYA again tonight...that black dot test was probably the trickiest one for me. If I'm right, and my CYA is at 90, then I'm thinking my CYA was higher than what was noted on the paper from the pool store testing, right from the start. Thankfully, I didn't add as much stabilizer as they wanted me too. And if I'm understanding Richard320 correctly, that is the reason for my cloudy water...I thought my CYA was good, so I was keeping my Chlorine level accordingly, but all along the CYA was probably higher.
    Fingers crossed that my reading is wrong....I really don't want to drain the pool!!!
    ~approx. 17,000 gal
    Aug 2010
    Dallas, TX
    4,052
    Without a SWG, you want CYA to be in the 30-40 range anyway.
    CYA isn't the root cause of cloudy water. FC too low for your CYA level is.
    Here's an instructional video on testing CYA.
    https://www.youtube.com/watch?v=NxaqoW-_MCs
    Apr 2013
    NC
    65
    Thanks, RobbieH. I retested a couple of times tonight and got the same number...90...BLEH! We went ahead and drained some water and refilled it. Added more chlorine...gotta go get more tomorrow! Lol...had I known how much chlorine I'd be using, I would've bought stock! :0). Good news is the water isn't any cloudier than yesterday. Hopefully we've caught it in time.
    Apr 2013
    NC
    65
    Here's an update and a question. The pool is almost all the way clear, the bottom has what I assume to be algae, it's a green powder (I say powder because when you gently sweep it, it fluffs up into a cloud.) Although there are readings that have changed, like the pH is now at 7.8, but I've moved the return so that the water doesn't break the surface, so I'm hoping that will help..anyway...I think once the green powder is gone, we will be really close to normal!
    My question is how do I get that powder out? My husband vacuums it regularly, but we haven't since we've been trying to "de-cloud" it. Now that things are clearing up, the bottom needs vacuumed but when he tries, it fluffs and the pool water becomes a teal color again. We have a cartridge filter and are planning to change the cartridge tonight to see if that will help. The vacuum we use is that little intex vacuum hooked to a hose (only used for the pool, never touches the ground.) It does fine with bugs and leaves, but there's no way that thing will catch those fluffy little particles. Any suggestions?
    ~approx. 17,000 gal
    Butterfly's Avatar
    South Carolina
    10,045
    Brush the pool at least once daily and let the filter clear it out.
    Apr 2013
    NC
    65
    OK, thanks, I'll brush it and change the filter when I get home... ...we'll be glad when this is over, we are sooo ready to get back in!!
    ~approx. 17,000 gal
    Apr 2013
    NC
    65
    Hello from cloudy-pool-land! Ok, we brushed the pool, changed the filter and the green crud infiltrated our waters again. So, I went back to the basics. I read more about slamming the pool and rechecked all my numbers..pH was up to 8.0. After reading some about slamming, seemed important to get my pH down to around 7.2, so we bought and added the proper amount of muriatic acid and got our number down to right around 7.3. After that, we brushed the pool again and added 2 - 121oz jugs of chlorine, then a few hours later (this AM) we brushed again and added 3 -121 oz jugs if chlorine, to raise us up to slam level. My husband has been home all day and has brushed the pool down about every 2 hours and has added another 4 - 121oz jugs of chlorine. The pool is cloudy, but not green, it's a cloudy blue. My question is, what now? I'm sorry to say, we don't have the higher choline test kit...not because I'm trying to be defiant, it's because we simply don't have the money right now. So here we are, I know the algae is dying, be cause my numbers are off the chart and the water isn't green. Do we just keep brushing, testing (to make sure it stays over the limit) and wait for clarity? Any help will be greatly appreciated!!
    BTW....we have turned off the SWG during this process.
    ~approx. 17,000 gal
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,984
    Now it's just the agonizing wait for the cartridge filter to clear it. You can leave the SWG on, which will lower the demand for liquid bleach, but be sure you shut it off when it's time to run the overnight loss test.
