Thread: Need to SLAM pool w/SWG but CYA is <30. Should I raise my CYA first?
    Jun 2013
    Dallas, TX
    105
    Have been away on vacation for a few weeks. Came back to a pool just starting to turn green. My FC is 0, CYA is <30 (low as my kit goes). Wondering if I need to raise my CYA before shocking with bleach, or if I can adjust after?
    Asking, as this chart doesn't list levels for CYA below 60
    Levels:
    0 FC
    7.0 pH
    170 tA
    <30 CYA
    (SWG, 35k gal)
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Need to SLAM pool w/SWG but CYA is <30. Should I raise my CYA first?
    If you're shocking with bleach, you use the chart for a bleach pool.
    Once it's all clear and done, then you can jack the CYA level up for your SWG. Low CYA is probably what caused the problem in the first place; the sun got to the chlorine before it could get to the algae, and the SWG couldn't keep up with the demand.
    Jun 2013
    Dallas, TX
    105
    Ah, I was just looking at the SWG chart. If I use the lower CYA levels from the non-swg chart, looks like I should shoot for 10-12 FC for a shock level.
    Agree that my low CYA was likely the cause.
