Thread: Intex 15x36 metal frame green
    Jun 2013
    MA
    104
    I was hoping someone could give me some advice. I am working with a 15x36 metal frame intex pool that has turned green. I was away for a couple days and then had a huge rain storm. I am currently using a TF-100 testing kit
    Chlorine 5
    Aklinity 60
    PH 7.2
    CYA under 20 ( I will be adding more stabliler)
    Should I add more chlorine to shock it? Thank you in advance for you help.
    18x48 ultra frame AG Intex pool 6423 gallons
    Krystal Clear Sand Filter Pump Model SF70110
    Test kit - TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Intex 15x36 metal frame green
    Quote Originally Posted by brickladyt View Post
    Chlorine 5
    Aklinity 60
    PH 7.2
    Yes, you should raise FC to 10 and recheck and replenish it repeatedly until it passes all three tests in the Shock Level and Maintain process article.
    Jun 2013
    MA
    104
    Ok I thought so. I'm actually helping a friend with hers. This site was so helpful with helping me last year when I had the same problem. I just wanted to double check I was remembering right.
    Test kit - TF-100
