Thread: Missing Item from TF100
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    If you have a 10cc syringe laying around (check your medicine cabinet) throw it in your kit. It is a great way to fill your test tubes accurately. I just get one big sample from the pool and bring it inside to do my tests. Much faster/cleaner and saves multiple trips to the pool for each test.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    May 2014
    Toronto area, Canada
    16
    Re: Missing Item from TF100
    I do the same thing and it works great. I was planning on buying the sample sizer, but the syringe has worked so well that I no longer think it's needed.
    25k gal IG Vinyl, 18 x 36, installed 1992
    AquaRite T-15 SWG
    1HP Hayward SuperPump SP2607X10A, Hayward S220T sand filter
    250k BTU Teledyne Lars gas heater
    Zodiac G4, PoolSkim
    Fort Worth, TX
    83
    It is really handy and saves time and aggravation.
    You can buy them at any pharmacy. They're called oral syringes.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
