Thread: Sand filter problem has me ready to replace everything
    Jul 2014
    South Bound Brook, NJ
    9
    Hey guys and gals,
    I've been a stalker on this site for a while. Just registered a username so I could post. You have been helping me for a year now, thanks!
    I have a waterway sand filter, 22 inch with multiport on top. I had a feeling that dirt was going through the system, back to the pool. I used a slime bag on my last cleaning and sure enough, that bag was filled with big pieces of the stuff I just vacuumed off the floor. I pulled the sand out and checked the latterals, they are good. My thinking was that maybe the pipe from the latterals was allowing the pressurized water to go straight back in to the pool, not through the sand. Lastly, I looked at the spyder gasket and it looks good. No nicks or anything. Then I thought maybe the gasket wasn't seated to the surface. How could I check that the gasket is sitting properly?
    I have always had cloudy water. I don't the filter is doing it's job but now I have proof that the water is going around the sand (not channeling but going straight back in to the pool).
    Thank you in advance for any insight on my problem!
    Sean from Jersey
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Sand filter problem has me ready to replace everything
    If the laterals checked out, it's probably the MP valve itself. Is the gasket on it in good shape-no flat spots----lubed---good spring tension?
    Jul 2014
    9
    Gasket looks good, lubed it up. Spring is tight on the handle but I can't tell if the gasket is actually sitting on the surface. That's where I am thinking the pass through is happening. How can I judge if the gasket is sitting right?
