Results 1 to 7 of 7
Thread: Chlorine tablets with SWG?
    Feb 2010
    Sacramento, CA
    35
    Going on vacation for about ten days. Have had some issues with SWG recently. It seems to be working fine right now but am nervous about an issue arising while we are gone. Is it a bad idea to put a chlorine tablet in the skimmer before we leave as a precautionary measure? I have a friend that can come by once or twice to check on the levels but he doesn't have time to do much more. Thoughts?
    Rgds,
    Dominick (Inground Pool Newbie)
    650 sq/ft - 20k gallons
    Free-Form Gunite with Granite Ansylbrite Finish
    40 sq/ft 18' raised spa
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Jun 2014
    Boca Raton, FL
    101
    Re: Chlorine tablets with SWG?
    My skimmer will eat a tri-chlor puck in about 16 hours of run-time. You say he will come by maybe twice in 10 days. I don't think that will help stop an outbreak in the event of a swg failure.
    I'm guessing that a puck a day would raise you CYA level about 15ppm over the 10 days. I don't think you want that either.
    If he can check the CL level twice, I would have enough CL jugs around to raise level to shock, in the event CL drops below normal. It sounds like you might need them when you get back anyhow.
    I would say enjoy your vacation and if you come back to a green pool or empty CL jugs, you know you need to fix that swg.
    16x32 DiamondBrite kidney, 12,500 gal. (circa 1985) 3/4hp Hayward SII, Harmsco BF84, Taylor K-2006, Hayward SwimPure Plus / Tcell-15
    Boca Roton, Fl. USA.
    prior 17k gal. vinyl, Sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    What is the current CYA level?
    If you have tabs in the skimmer, the pump needs to run 24/7.
    You're done SLAMing when:
    Feb 2010
    Sacramento, CA
    35
    As of yesterday afternoon the CYA was 90.
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    With a CYA that high, you do not want to use pucks. Use bleach to bring you up to shock level. Keep your SWG running so that it will keep up with the daily chlorine demand. If the SWG fails some time during your vacation, you may still be okay (or maybe not if it fails right away). If it does not fail, you will be at shock level when you get back.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Feb 2010
    Sacramento, CA
    35
    How much bleach? Pool is about 12,000 gallons.
    Rgds,
    Jandy DE60 filter
    Jandy Aquapure 1400
    Jandy Aqua link PDA
    Jul 2011
    phoenix
    133
    Quote Originally Posted by Tugsie77 View Post
    Use this handy tool to help you calculate how much you need depending on how high you want to take it
    http://www.troublefreepool.com/calc.html
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
