Thread: Skimbi floating skimmer
    jmcdtucson's Avatar
    Jun 2014
    317
    Has any one tried this skimmer? It has good reviews on Amazon, better than the intex one.
    Also wondering if I can connect the vacuum from the Intex Deluxe Maintenance kit to this skimmers hose.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Oct 2012
    Houston, TX
    186
    Re: Skimbi floating skimmer
    From what I can tell it seems to be like the small Intex model which is ok but not as good as the Intex deluxe which is bigger and worked better. It also has the larger 1.5 inch hose rather than 1.25.
    I had both before finally doing thru the wall Hayward.
    Just my .02.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Oct 2012
    Houston, TX
    186
    I went to the garage to take a pic of them both side by side but it looks like I finally pitched the small one. However the deluxe one is 8 inches across the opening, for reference.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    It looks just a little smaller than the Intex deluxe skimmer. I use the deluxe and find that it works just fine for my 18' round pool. When the kids start getting rowdy I turn off my pump and pull the skimmer. I have had them break the arm from rough housing. My next pool is going to be a more permanent pool with through the wall skimmer but until next year this deluxe one works great.
    You should probably check on what hose size you need for your setup. You can go bigger but I wouldn't go smaller.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
