Thread: Help, water level dropping fast!
    Jul 2014
    Pendleton,IN
    2
    I have lost at least 1 inch in water level in the past 24 hours. I have only owned this pool for one season and have noticed that the water levels would drop more than normal evaporation. There appears to be a leak somewhere in the under ground plumbing. My pump and filter are set up inside my garage and there are no leaks around that set up. In the past 48 hours my water level in now below my skimmers. Are there any tests that I can do without calling the expensive pool places? Any help or suggestions would be greatly appreciated.
    20x40 IG vinyl 38900 gal, Hayward s-240 filter, 1 hp pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Help, water level dropping fast!
    Without getting a pool professional involved (some have sounding equipment to "hear" the leak) is going to take normal troubleshooting skills.
    Some thoughts:
    If your plumbing has multiple runs (i.e. drains/skimmers/returns/waterfalls etc.) that can be separated via your plumbing/valves you can turn off sections for a day or two to see if you can isolate the leaking section.
    Search your yard looking for wet areas. You may need to look under decks/shrubs and all hidden areas. If you have an idea of the location of the buried pipes you can probe the ground looking for wet areas.
    If you can remember when you first noticed the water loss beginning, did you do any yard work in that time frame. Trees/bushes/posts or anything planted/dug into the ground may have nicked/cracked a water pipe causing a slow leak. Except with freezing and frost heave pipes don't generally start leaking on their own without outside "help".
    Support the site
