Results 1 to 9 of 9
Thread: Taylor CYA reagent
    Nov 2007
    Rockland County, NY
    65
    Taylor CYA reagent
    Hi All....I ran out of CYA reagent in my TFT-100. Can I substitute the Taylor reagent that Leslie pools sells ? Thanks.
    Rob
    27ft Above Ground Pool
    Sand filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Taylor CYA reagent
    In Pool School there is a thread that compares test kits, and it says the TF-100 uses all taylor reagents so I don't see why not?
    Guest
    Yes, it's the same reagent.
    Nov 2007
    Rockland County, NY
    65
    Thanks for the answer!
    Sand filter
    Jul 2008
    Dallas, Texas
    27
    They give a ridiculously small amount compared to the other tests. Now I know the CYA is the most stable but come on there is like enough for three tests total!
    Brian
    30,000 Gallon Renovated Pool and Spa
    Flagstone Coping and Wall
    Onyx Quartz Plaster
    72 SF D.E Filter
    Polaris 280 Cleaner
    Jandy Aqualink Control Center and Palm Remote
    30,419
    Brian, I assume you are talking about the Taylor K-2006.
    The TF-100 I put together has enough CYA reagent for 8 full tests. If you are clever and know your CYA is above 40 or so, you can mix 1/2 the amount called for in the the test and get 14-16 tests.
    You are correct in that CYA should be an infrequently tested parameter. Some folks test twice yearly......I do it about three-four times on average.
    All of the TF-100 chemistry is Taylor chemistry BUT it is not all compatible. Make sure your Taylor reagent numbers match mine if you are ordering to replace reagents in your Taylor kit....(Please do, I'm cheaper and faster )
    Jun 2008
    Marana, AZ
    347
    Exactly what is the ratio of CYA reagent to water?
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    11,969
    Oh sure, now you tell me.
    I guess I'm just not clever.
    30,419
    50/50
