Results 1 to 9 of 9
Thread: iAqualink IQ900-A issues!
    Angry iAqualink IQ900-A issues!
    I've had the IAQUALINK set-up for awhile, several months, all working flawlessly once programmed. We had a bad storm here on Thursday, knocked out the internet (Uverse). Technician came out on Saturday and determined the modem/router was fried and replaced it, also giving me a new SSID and password.
    So, I unplugged the connector from the main box, hooked the laptop back up to the interface and went through the set-up process again, because that's the only way I knew how to update the network info, however, I keep getting an error after entering all the info:
    WIFI TOOL
    Runtime error "52"
    -bad file name or number
    I've tried another laptop, I've tried my really old laptop, I even tried doing a system restore to 2 months ago on my main laptop that was used for the original set-up, hoping to clean the registry, but still, same error.
    Any ideas? It's really frustrating! and of course if you click on the support tab online, it just says call or email....and they aren't open until Monday.
    appreciate the help!
    20k gallons
    In ground plaster pool
    Hayward Pro-Grid DE4820, Pentair Whisperflow 2hp
    Spa
    Re: iAqualink IQ900-A issues!
    so I took it down and hooked it up to my router inside, nothing. here is the error I get when trying to do the wifi set up
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Does the new router have the ability to broadcast "B" band? If your iAqualink is 7 months old (ver 1.0), it will only function on B band. If you are hooking up hard wire, you will probably need to uninstall all the software first and then re install. If that still doesn't work, I would call Jandy and have them walk you thru everything, at that point, i would begin bugging them about sending you the new version (2.0) for no charge to replace your current mess. IMO, they shouldn't have ever rolled out 1.0 because of it's requiring the very old, very slow, b band to run on.
    Factory Warranty Station for:
    Quote Originally Posted by Pool Clown View Post
    Software revision date according to the box is 3/21/14. That said my router does b/g/n, so it shouldn't be a problem anyways. I plan on calling them this morning and see what they say.
    20k gallons
    Spa
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by MrJonMan View Post
    iQ900-RS = 1.0 version
    iQ20-RS = 2.0 version
    Note: if your router says it supports b, you still have to turn on dual band and set b to the second band broadcasting. Your cable tech may not have turned on the dual band or set the second band to b. Either way, i would bug Jandy.
    I def have the iq900.....
    And sorry I should've been clearer, when I go into the advanced set up for my router, it says it is broadcasting b/g/n
    I wasn't able to call before I left the house, and I know if I try while I'm in the car, they're going to need me to do stuff that I obviously wouldn't be able too
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    Also check to make sure it sends out 2.4gigs and not the 5. what LED's are working off the aerial?
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Quote Originally Posted by malcolmb5325 View Post
    the power is lit and then the network light is blinking because it is unable to connect. I'm actually on hold now, waiting to talk to tech support.
    side note: came home to high filter pressure yesterday, day before it was high so I backwashed (DE), then day later it was even higher, backwashed again yesterday, thinking maybe it was just really dirty from July 4th get together, plus dogs in the pool at times. Just checked it now and its about 5psi higher than normal.
    20k gallons
    Spa
    Simple fix from tech support....
    apparently an error only on Windows 8/8.1......
    all I had to do was plug the device into my computer, find it on the drive list (My Computer), right click, properties, Tools tab, then selected "fix this drive". Boom, fixed.
    went through the set up as normal and it works fine now.
    Now onto my filter issue.....
    20k gallons
    Spa
