Thread: I didn't notice explicit bonding wires attached to the rebar
    greebs's Avatar
    Jun 2014
    Houston, TX
    3
    Hi,
    We are in the process of building and the gunite is in already - I never heard the PB talk about bonding. I didn't notice explicit bonding wires attached to the rebar before they put the gunite in. Can the pool be bonded after gunite? Our gunite was just applied - no electric work yet. The rebar is still sticking out around the lip of the pool perimeter so I am assuming bonding wire can be attached to the exposed rebar. The electrician has yet to come and I would like to insist the pool be bonded if it is still possible.
    Thanks!
    ____________________________________________________________ ____________________________________________________________ ___________________
    25K GAL, IG, Spa, Diamond Brite Oyster Quartz, Ozone, Pentair: CCP420, IntelliFlo, MasterTemp 400K BTU, Easy Touch Wireless, IntelliBrite LEDs, TF-100, Build 7/2014
    Re: I didn't notice explicit bonding wires attached to the rebar
    As long as there is still exposed rebar the bonding can be connected. Bonding is normally done by the electrician. If an electrician hasn't been out yet then they will presumably take care of it when they show up.
