Thread: Adding DE after backwash
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Okay, I have to ask. I know the conventional wisdom on this sight is to add a percentage (haven't looked up the number yet) of the required DE after a backwash. Seems logical. It's obvious that all of the DE will not leave the filter after a backwash, but should I override the instructions of the manufacturer? They say to add 100% (4 lbs) after I backwash.
    Ed
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Adding DE after backwash
    I believe that magic number is 80%.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Yours is a bump-type DE filter, so it isn't backwashed in the same manner as a screen type. I would hope the banging would knock the DE off better than just running the water through backwards like a conventional filter. Don;t know what to tell you.
    You might want to change the thread title to reflect the bump type filter and hope someone with first hand experience sees it.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Good catch Richard, it is a bump style filter.
    10,800 gallons
    TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Bumping is just to knock it loose to be re-distributed in the filter. Opening it up and hosing it out is the best way to clean a DE filter, then you give it 100%re-charge.
    Love TFP? Become a
    TFP Supporter!
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    That's not necessary every cycle, back washing is fine for most of the season.
    10,800 gallons
    TF-100 Test Kit
