Thread: Is this Normal?
    Is this Normal?
    Hello
    I have lots of tiny bubbles coming from my spa spillover returns. I've never really noticed this before. They aren't big are bubbles, just many tiny little ones.
    Thanks for any help you can provide.
    Pool/Spa = 15800 gallons; Depth = 3 X 5 X 4; Pentair 520 SF Cartridge Filter; Pentair 400K BTU Heater; Pebble Surface
    Re: Is this Normal?
    Do you have a SWG. Small bubbles from a SWG when the cell is active is normal. Otherwise, that suggests a suction side air leak.
    Re: Is this Normal?
    Quote Originally Posted by JasonLion View Post
    Thanks Jason - I do not have an SWG - Is this an easy fix or something I should have my pool company repair?
    Thank you!
    Re: Is this Normal?
    Suction side air leaks can happen from a wide variety of reasons, some simple, some complicated. I recommend looking at the Suction Side Air Leaks article in Pool School and at least trying some of the simpler things before calling a pool tech.
    Re: Is this Normal?
    Thanks - I have read... Looks like I have a bad o-ring on the chlorinator lid. I'm sure that would cause some of it. Would it not? I did the water test on the pump basket and also noticed there appears to be a leak there too.
    Thanks so much.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Is this Normal?
    that will do it.
    Quote Originally Posted by pktman View Post
    Thanks so much.
    Divin Dave,
