Thread: Still have filter issues
    Sep 2007
    Mobile Alabama
    33
    I added cya acid again yesterday and there was still some coming out the returns in the pool. Maybe a handful out of each my best guess. After the first time I noticed this I took the filter apart to look at the sand. I seemed to be channeling around the pipe because all the other sand was packed hard. Okay, broke the sand up and cleaned a load of junk out the sand using a water hose. Next it was suggested to change my wagon wheel gasket. Did that and actually had to replace the spring. Acid still getting by the filter. Now what should I do?
    16x36 vinyl
    300 lb sta-rite sand filter
    3/4 hp sta-rite pump
    Aquarite SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Still have filter issues
    Can you post the particulars of your pool and filter/pump? Better yet, add it to your signature so it's always handy when you ask a question. You get there by going to the User Control Panel under the TFP logo in the upper left.
    Sep 2007
    Mobile Alabama
    33
    I was just told by the one pool store to replace the lateral assembly in the filter.
    Another fellow told me that it was normal for some particles to get by?
    16x36 vinyl
    Aquarite SWG
