Results 1 to 12 of 12
Thread: pool light
    Jul 2014
    Hudson, wi
    81
    pool light
    I'm trying to pin down my fc usage and want to clean my light(1) and ladder. Do I need to drain my pool below the level of the light to remove the cover and clean it?
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: pool light
    You don't need to drain if you don't mind getting your hands and tool wet, it's much easier this way. You should only need to pull out the screw (at the top) and it tilts forward and there should be enough cord behind it to lay it up on the decking. Others have more screws.
    The video shows the guy in the pool doing it but you should be able to reach it leaning over the edge.
    http://www.youtube.com/watch?v=vTO-wYmhpVU
    Solar Blanket, Well Water, Borax Added. 68
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: pool light
    Any luck with it ??
    Jul 2014
    Hudson, wi
    81
    Re: pool light
    The deck around it was all wet and I didn't feel like getting wet. I'll pull it out and clean it tomorrow. Around the outer edge was pretty gross so I am guessing there is algae in there that is eating my fc. My light is also in the deep end, hope I don't drop the screw
    Thanks
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: pool light
    Now that you've said it out loud you know what's going to happen
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: pool light
    Quote Originally Posted by onestout View Post
    Thanks
    When I pulled mine to clean behind it I had the vac hose all set up and vacuuming to waste so when the light came out all the stuff that floated out behind it was sucked right out of the pool.
    Support the site
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: pool light
    got a magnet? attach it to the screwdriver to help keep the screw connected to the screwdriver.
    MBG75's Avatar
    Jun 2013
    Long Island
    184
    Re: pool light
    Not all stainless is magnetic.
    25k IG vinyl SWG Haywood 4830de 1.5hp TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: pool light
    Some screws are brass = not magnetic. Just be careful with it or have your suit and goggles ready.
    Isolated Spa - 345 Gallons
    Jul 2014
    Hudson, wi
    81
    Re: pool light
    And so I wake up this morning and it is raining.... Guess I'll have to wait a bit for my morning test and to pull my light, so much for staying dry during this.
    Apr 2011
    Murrieta, CA
    2,360
    Re: pool light
    If you've got an extra set of hands to help out have them hold a skimmer below the light to catch anything that drops. Most lights can be reached by laying down on your chest and reaching into the water.
    http://www.youtube.com/watch?v=eFUfiSKEh7A
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: pool light
    It's not raining, the sun is out ... is the light out yet ??
    Do I need to come over there ??
