Thread: Psi 29 at speed 4. Do I need to be worried?
    Jul 2013
    Chandler, AZ
    43
    Hi, I haven't done any cartridge filter cleaning since I moved into my current home with pool 15 months ago.
    Today I noticed psi is 29 at speed #4. I have variable speed pump.
    But, at speed #1 - psi is 2
    at speed #2 - psi is 14
    at speed #3 - psi is 18
    at speed #4 - psi is 29.
    Should I be worried. Verified that my gauge goes to zero when the pump is not running.
    Please advise.
    My current test numbers- FC - 7, PH - 7.4, TA - 90, CH - 625, CYA - 60
    12x40 In ground, 16K Gallons, Pentair VS pump, 420 catridge filter, 140HC Heatpump, Stonescapes pebtec surface, Chandler, Arizona
    38,524
    Re: Psi 29 at speed 4. Do I need to be worried?
    That could be normal, although not likely a need to be running at that high a speed.
    Jul 2013
    Chandler, AZ
    43
    Thanks!
    wjr75's Avatar
    Jun 2013
    IL
    836
    I would clean the filter in any case. I just use a garden hose with a high pressure nozzle. My filter runs 10psi most of the summer and I clean it in the spring when I open the pool.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    May 2014
    Mesa, Arizona
    180
    Especially since we just had that dust storm roll through the other day I would definitely clean the filter. Howdy neighbor!
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Record the clean value at high, and clean when the pressure climbs 25% of the clean value.
    http://www.troublefreepool.com/conte...er-maintenance
