Thread: Heat Problem - Display Blank
    Jul 2014
    Ottawa Ontario
    55
    Hi there!
    I have a Haywood natural gas pool heater, H250FDN. I've being trying to diagnose a problem with the display as it is blank. The heater itself is functional and running but I would like to see what is actually going on!
    So far, I have checked the four fuses on the fuse board and all are good. I also checked the spade fuse on the main board; it is good too. Any suggestions as to what else to check? Any ideas as to what may be wrong?
    P.S. I did a bit for searching before posting this. Seems most people got an error code. I have not seen one yet.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Heat Problem - Display Blank
    So the display is totally blank but the keys for turning it on/off work? If that is all, then you had a bad display board.
    http://www.parts4heating.com/Hayward...0059456600.htm
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
