Results 1 to 10 of 10
Thread: Charcoal briquets or lump charcoal?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    Which do you prefer? Since discovering the lump charcoal we like it so much better. You don't need as much. It is ready quicker and it does not leave that bad charcoal after taste in your mouth, if you use anything less than Kingsford.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    Re: Charcoal briquets or lump charcoal?
    Lump. We use Basques, Maple Leaf, or Royal Oak.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    texasbrew's Avatar
    Aug 2007
    Humble, TX
    I prefer Royal Oak lump if I can find it. Otherwise I use K. I have never had a problem with taste with briqs but I don't use lighter fluid. I use a chimney starter and make sure that the coal is ready to grill (unless I am smoking and then I do a Minion start).
    PG-500, WSM, 20K Gal gun pool w/ Aqua Pure 1400 SWG, flagstone coping, gray plaster, DE Filter, 400K BTU nat gas heater and Polaris 280 cleaner
    NO comparison between lump and briquets! Lump!!!! (even though I gave up on charcoal a long time ago and switched to propane!)
    Mar 2008
    Central VA
    Yep, the purists will tell you Lump, and since I've started using it, that seems to be the way to go (the less fillers the better) my BGE, I can leave the unused charcoal and relight it the next time, so it helps make up for the price difference.
    AND dontcha love the wood chunks (soaked) mixed in with the lump charcoal? Then you really do have a 'smoker'!
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    I use lump 99% of the time. I am trying to figure out the control for my drum smoker with lump, it seems to like briqs better. I however, like the taste of lump.
    For any Ceramic or insulated unit, I would recommend lump, as you can close it down after a cook and reuse the lump the next cook. The Briqs fall apart on the second go around.
    I use wood chunks and do not soak, as I am lazy.
    Royal Oak for me, as I can find it at Rest Depot cheap or Wally World is need be.
    In Ground Pebble Tec Play Pool
    27 ft x 17 ft x 4.5 ft approximately 12,000 gallons
    Salt Water Cell System with in ground filter system
    no-mas's Avatar
    Jun 2008
    Guess I'll be the contrarian -
    I now mostly cook with gas, but when I want to use my weber kettle, I use briquettes. I find briquettes burn longer and more evenly, but slightly cooler, than the lump charcoal; and the lump is more ashy while cooking - anytime I'd open my kettle, very fine ash would fly around and onto my food. The only briquettes I've ever used are Kingsford.
    I've always loved cooking with charcoal - When building our outdoor kitchen, I made sure to plan a storage spot for my kettle, because I figured while gas is more convenient, I'll use the kettle more frequently. I bought a weber summit s450, with a seperate smoker burner/box, and boy do I love that grill. I only use my kettle now when I'm cooking LOTS of food and need the extra grilling space, because that little smoker box really works great - imparts a nice smoky flavor to my food.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Jul 2007
    South Carolina
    I use both, lump for grilling because of the hotter fire and hardly any ash left after they burn and briquets for smoking because they last a lot longer.
    But hey use whatever you like just get out and do it often. We usually grill several times a week.
    Pete in San Antonio
    11K IG Gunite/325 Serires Hayward cartridge
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    Speaking of being able to continue to use lump for multiple cooks.
    When I made my first pork butt, I filled the firebox with lump, probably 8 lbs worth. I have have cooked 4 times so far and may get one more and still have not had to clean out the ash yet.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Northern CA
    I've only used charcoal in my WSM (Bullet), one day I will have to try Lump.
    I don't soak the smoke wood, water doesn't penetrate far enough to make a difference.
    34'X 15' 3'-8' depth 22,000 gallon in-ground Grecian style built July of 2004, Blue Tahoe PebbleSheen, Poolpilot DIG-220 w/SC-60 SWCG, Pentair WFE-4 1HP filter pump, 6' S/S Waterfall and WFEDS-6 2 spd Waterfall pump, Letro Legend Platinum cleaner w/LA01N pump, Sta-Rite DE filter S8D110 53 sq. ft., 648 sq ft. East facing Solar panels w/Pentair LX 220 solar control, 6' Pewter Gray SR Smith Glas-Hide dive board on black powder coated cantilever stand w/SS hardware
