Results 1 to 14 of 14
Thread: From Pond to Pool
    From Pond to Pool
    We bought our house 11 years ago and with it came a pool. We wanted to fix the pool up but there was always something else needing to be done, so the pool was put on hold. My wife said fix it or fill it in, its embarrassing, So this was the year to finally do it. I've done all the work myself except pouring the concrete (thanks to my neighbor) and the vermiculite & liner(pool company). I think I started in March and filled it with water on July 14th. We still have alot of plans for the landscaping which has not even been started yet, maybe in a few weeks after I spend time swimming with the kids.
    Just some of the concrete that was broken up
    We also had about 10 to 15 bull frogs living in the pool & one turtle who appeared this year
    Digging out the walls to repair the panels where they used wedges to hold them together. I used stainless stell brackets & bolts to replace the wedges
    Ground water was always a problem. I had never seen the bottom.
    I had to repair the skimmer which was not installed correctly & then pressure tested the lines after I relocated the pump & filter to the other side.
    Installing a light was a must
    Used a ladder so I didn't fall in while installing the light
    My wife thought the concrete was not going to come clean... good ol pressure washer
    Put in 12 tons of gravel brought it up to 6 ft from 8ft & made the slope from shallow to deep end less drastic
    2 yrds of topsoil to repair the sides & the plastic was to cover up the dirt to protect it from the rain (Thats me)
    This is where the pool guys stepped in
    My daughters can't wait
    I saved about $6000.00 by doing the work myself. Some of the estimates I got wre way too high the highest being $14,000 with me not doing anything.
    I would like to thank everyone on this site for there help & knowledge & the BBB method is working great.
    I'll post some pics of the pool now that it's full later (need to take some)
    Thank You Again,
    One Very Happy Family
    Anthony
    16x32 16000 gal IG vinyl liner
    Hayward S244T Sand filter
    Hayward 1 1/2 hp 2 speed pump
    Butterfly's Avatar
    South Carolina
    10,045
    Re: From Pond to Pool
    Anthony! When you said "from pond to pool", you weren't kidding!
    You did a great job! Congratulations!
    Your little girl is precious and I'm sure your family is happy with the transformation.
    Can't wait to see the pool full of water!
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,452
    WOW! What a transformation!
    Just W~O~W!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    That's gotta be at the top of the list for best transformations EVER!
    Great Job!
    I bet your wife is just thrilled now!!!
    Rocklin, Ca
    467
    Anthony,
    That was a cool story. You did a great job in a pretty short time by yourself.
    What did you do with the turtle and frogs?
    I can't believe the pool guys had to rent a mixer. Don't they use one often enough to justify buying one?
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    WOW! I'm very impressed! Beautiful!!
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    That looks great!! Good job!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    tootie's Avatar
    Apr 2008
    NC
    46
    "Googly Moogly or Holly Macaroni"
    My Husbands name is Anthony, but I'm sure as... you know what that he could have NEVER
    pulled this one off..
    What an awesome job
    24' x52" Intex metal frame
    Pentair sand dollar SD60
    Original pump 2500gph
    "5 years of BBB, and loving it"
    Jul 2007
    Northern NJ
    299
    That does look great! I'm wondering though, when did you cut out the light?
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Quote Originally Posted by anm1227
    Actually, it looks like you had LOVELY landscaping, only it was IN the pool and not out!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Sorry I did not reply, We were away on vacation.
    The frogs & turtle are alive and well living in a pond about 1/2 mile away.
    I had to stop filling the water when it hit the light so the pool guys could come back the next morning to cut everything in,and after he was done I filled the rest.
    As far as the landscaping goes we are still unsure what to do along the back fence, maybe river rock and some bushes, there is a pretty good slope down to the fence.
    I'll post some new pics this week & rename the post. Thanks for all the great replys,it makes me fell good that everyone likes it.
    Anthony
    West Michigan
    108
    Some guys can do anything! That was an amazing transformation. Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    WOW! What a project! You did an awesome job!
    Kristy
    In construction!
    16'6" X 33 Lagoon
    13,000 gallons
    rock coping
    tile border
    textured/colored decking
    Tahoe Blue Pebble Tec
    2 Deck Jets
    SWG (Goldline)
    Legend II Cleaner
    1.5 hp pump (Duraglass)
    Sand filter with zerobrite
    Rockcrawler's Avatar
    El Paso, Texas
    174
    EXCELLENT!!
    Maybe you get get in the Pool Makeover business
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
