Thread: UN-stabilized pucks
    Mar 2007
    Collierville, TN (near Memphis)
    94
    UN-stabilized pucks
    Does such a thing exist?
    There isn't anything you can use in a conventional puck feeder that doesn't have stabalizer/CYA.
    Accu-Tab, web site, makes cal-hypo pucks that can only be used in their special puck feeders.
    HTH Duration capsules are plastic capsules containing cal-hypo that you can put in the skimmer. See for example here.
    Both of these contain calcium, which is often fine in the short run but over time can become a serious problem.
    JoshU's Avatar
    New Orleans, LA
    543
    Just be sure to NEVER add cal-hypo into a chlorinator that has had tri-chlor tabs (or tri-chlor into cal-hypo).... It would cause a dangerous combination. The two chemicals shouldn't even be stored near each other.
    Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Jun 2007
    Southington, CT
    2
    There is another Cal-Hypo 3-inch puck available under the Sustain name. I travel frequently and use this product for my daily chlorine use. I do use bleach to shock but find this puck helps me maintain my chlorine level while I'm away. The puck is not wrapped in plastic and does not erode in a day or two. Every bucket comes with a plastic dispenser and a sliding lid. It holds two pucks, which usually last approximately one week. The plastic dispenser is placed in your skimmer basket. Sustain also makes other products for shock, clarifying, etc. but I don't use any of them. I'm a BBB kind of guy who uses these pucks to maintain my chlorine without stabilizer. They have a website at www.askjoepool.com if you want to locate a dealer near you.
    18K gallon free-form gunite pool w/ attached 4 jet spa. Sta-Rite S7D75 DE filter, Sta-Rite Max-E-Glas II pump with two-speed 1HP motor.
