Results 1 to 7 of 7
Thread: PH Problem
    May 2014
    Quad Cities, IL
    6
    PH Problem
    I have a TF-100 test kit on order, my cheap test kit keeps coming back as high ph. I keep addding granular sodium bisulfate i think it is to lower but dont see a change. How soon can i test after adding? I have added two doses by mixing it in good in a pail of water.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: PH Problem
    Best thing for lowering pH is Muriatic acid 31.25% (20* baume`).
    Are you using test strips? they go bad rather quickly, and may be giving you false readings.
    If you are using a color match (phenol red) kit, if your pH is higher than the kit will read, it will show as the highest color until you have it with the range of the kit.
    Check out PoolMath link above, and put your pool info there. It will tell you how much of your chemical to add to bring it down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: PH Problem
    If you have high FC, you might be bleaching out the test strips.
    May 2014
    Quad Cities, IL
    6
    Re: PH Problem
    Thanks for the info, im using the phenol red. I did just have to shock it for an algae problem about 5 days ago.
    May 2014
    Quad Cities, IL
    6
    Re: PH Problem
    What would you guys recommend for an initial dose sinc my ph is measuring off the tester? Im thinking about plugging 8.3 into pool math and starting there.
    Re: PH Problem
    How much acid you need to use depends on your TA and borate levels, neither of which you have posted. Once you have entered those into Pool Math set current PH to 8.3 and target PH of 7.5 and try the amount it calculates for that.
    May 2014
    Quad Cities, IL
    6
    Re: PH Problem
    Ok...im still waiting for my tf-100 to show up....just trying to get ph lowered in the meantime
