Results 1 to 11 of 11
Thread: water leak.. at pipe.
    one side that is leaking it attached to filter. i could disconnect other side that is going to heater, but if i tighten it wont it break the silicon that they applied and become worse?
    18x38 IG
    Appox. 85000litres
    Jacuzzi laser sand filter
    1hp pump
    Municipal water
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    416
    Re: water leak.. at pipe.
    The way that connection was plumbed is not correct, and can not be tightening that connection.
    The pipes are glued with PVC primer and glue. Silicone sealer is generally not used in pool plumbing, so this looks like a temporary stop leak.
    The connection should have a Union (that allows adjustment) or male coupling at the filter connection - that fits over the top of the threads that you can tighten.
    The solution is to cut the pipe are remove both pieces (the 45 and the connection to the filter). And insert a union into the line at a minimum to allow for removal and adjustment. Use a pool grade union and not one from the Home box stores.
    You could also ID the brand of the filter and get the correct fitting to attach to the filter.
    If you need help maybe a friend could help. Its an easy fix if you have the right parts.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    It's a jacuzzi laser. But if the pipe is glued when I cut it it will be stuck in the filter side???
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    That is a really poor plumbing job. Cut it all out and install it like it should have been in the first place...you will thank yourself down the road.
    You have my sympathy on this one. Nothing I hate more than fixing a lazy guy's bad work.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Want kind of silicone can I use to seal it
    I'm selling my place I just need a temp fix. Has a very slow leak
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Apr 2013
    Sacramento, CA
    2,769
    Silicone is probably not going to seal it. Or only for a few days. Its going to fail faily quickly. Just about any silicone caulk will last a week or so. But this needs to be done properly.
    It's had silicon on for two years without a leak. And now finally a slow leak.
    Should I take old.off or just go over
    18x38 IG
    Appox. 85000litres
    1hp pump
    Municipal water
    Sep 2013
    Charleston, SC
    537
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    If they glued the pipe to the filter is it stuck there for good? I guess there is no way to remove and add a uniom if they glued it?!!
    Quote Originally Posted by blakeusa View Post
    Fixed, added thread tape
