Thread: Greetings.
    Jul 2014
    Corona/CA
    3
    Greetings.
    Hi, I'm Wayne Rogers and have been in the pool service industry around two years. Found this website searching for TDS data for my clients and found out I was misinformed from classes I took. Looking forward to a source of experts for knowledge and scientific data leading to a thorough understanding of pool water chemistry while obtaining expertise, knowledge and certainty in the field that will be conveyed in my work and demeanor.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Greetings.
    Welcome to TFP!
    If it's pool knowledge you seek, you've come to the right place.
    I'm guessing that you took the state recognized certified pool operator course. There is a lot of good info there, however there are also myths and outdated info being taught.
    A good place for you to start expanding your knowledge would be in our Pool School, starting with The ABC's of water chemistry.
    Good luck with your quest for good knowledge!
    Jul 2014
    Corona/CA
    3
    Re: Greetings.
    Thanks. I have not got my CPO yet but did get the pool chemistry cert from IPSSA. I'll check the ABC's.
    38,244
    Re: Greetings.
    Welcomed to TFP!
    There are some great posts from Chem Geek ... One is what is NOT taught in cpo classes.
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
