Thread: Total Alkalinity levels
    Jul 2014
    Lakeland, TN
    1
    I am new to this forum and have been doing a lot of research here about water analysis. I have an inground, vinyl pool with a SWG. I can't ever seem to keep my PH within normal ranges and have read on this forum to try and lower my TA. I do also have a fountain, so I am aerating about 10 hours a day. The last water analysis showed that my PH was FINALLY within range, but now I am worried that my TA might be too low. Here is my last analysis:
    Calcium Hardness - 255
    Alkalinity - 42
    Cyanuric Acid - 66
    PH - 7.5
    HELP!!!!! Is this ok? I don't want it to get to low that I damage any of my equipment, but this is also one of the first times that I have EVER gotten my PH to that number! I appreciate any help and comments that I can get!!
    38,284
    Re: Total Alkalinity levels
    Welcome to TFP!
    The key to understanding and maintaining the chemistry is a good test kit. I get the feeling that what you posted were the results of pool store testing which is typically pretty bad. I would suggest you invest in one of the recommended test kits.
    Generally the TA is not that important. The key is to keep the pHh in range and usually requires near daily testing and adjusting. Although yours is a little low and that should actually slow the rise ... I if you believe the test results.
