Thread: Gas Heater connection?
    I am doing a rebuild of my equipment pad with better optimized plumbing, a new pump, new filter and I will need to reconnect my gas heater to the existing pipe. It's connected today with rigid black iron pipe, and I'm wondering if it's now possible to use flex pipe from the shutoff valve to the heater. Since the height on the pad will change a little, that will make my life easier.
    Is it permissible via code to run the last two feet into the heater with flex supply line?
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: Gas Heater connection?
    Take that up with your local inspector. It varies from city to city.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
