Thread: Bleach in skimmer
    Jul 2013
    Greenwood, IN
    35
    Bleach in skimmer
    I have a cover on my pool. Is it ok if I need to add liquid chlorine to put it into the skimmer?
    38,000 gallon vinyl lined in ground pool with diving deep end.
    wetchem's Avatar
    May 2012
    Somewhere in the middle of Nebraska
    208
    Re: Bleach in skimmer
    I've a cover on my pool too:
    I've cut an old bleach jug open so that the top third is open; however the top and handle still work... like my g.ma used to do for cloths pins.
    I lift part of the cover by the return and scoop out pool water to about 1/4 to half fill the jug
    I dilute the few cups of bleach in that pool water and swirl to mix
    I then push the jug with the diluted bleach into and under the cover and slowly tilt it thru the top opening where the cap would have been and direct it towards the jet.
    Unless the experts here suggest it; I wouldn't normally add anything thru the skimmer in an undiluted state as there is a potential to degrade seals and other parts
    Intex Ultraframe 14'x3.5-Round (4000ish-gal) AG - Vinyl - Intex 5667EG Sand Filter 1600gph :)
    ( retired: 637R Crtrge 1000gph someday it may have another life as a water fountain... or feet washer! Solar Water Heater? )
    :mrgreen: Click here to Goto Pool School. :scratch: How Much Of What? Click Here - Poolcalculator.com :lookhere: TestKits
    30,426
    That's really a good summation. Doing it another way (directly into the skimmer) once or twice probably will do virtually no harm. Repeating that practice year after year is simply not a good plan. It's a little more work to do it right but your equipment will thank you for it.
