Results 1 to 8 of 8
Thread: Sand coming into the above grund pool
    Jul 2014
    old bridge
    4
    Calling for any pool experts. I continue to get sand in my pool, I had this issue last year so I started fresh before this summer. Emptied and cleaned out the Sand Filter, washed and cleaned all the pipes and laterals, all were intact. When I run the filter sand on a daily basis I get sand and prove it as I use a stocking around the water input into the pool and there is sand in it. Any ideas would be greatly appreciated!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Sand coming into the above grund pool
    Hi, welcome to TFP! Have you examined the multi-port valve spider gasket? It should not have any signs of excess wear such as loose spots, cracking, splits or tears. If it is in good shape lube the spider gasket and o-rings with silicone pool lube and re-install.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    old bridge
    4
    Thank you, I have not yet checked that, so basically unscrew the top part and look I am guessing? I can leave the rest of the top connected ?
    Jul 2009
    Houston, Texas
    9,429
    Yes, you should be able to leave the bottom half in place.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    old bridge
    4
    Does this look worn?
    Smykowski's Avatar
    Sep 2011
    3,065
    What kind of sand filter do you have? Can you put all of your pool/equipment specs in your signature? Also, please put your city and state in your profile.
    Jul 2009
    Houston, Texas
    9,429
    The spoke under your thumb in the first picture looks a little chewed up. I am surprised you were able to remove it intact. They are usually glued into place.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    old bridge
    4
    I am from Old Bridge NJ, I have a Heyward big round black sand filter, 18 ft round pool
