Thread: 2 speed pump + heater
    May 2014
    San Jose, CA
    153
    What is the best way to use a gas heater?
    with the pump on high or low?
    I have 1HP 2 speed pump with a hayward heater (100K), when the pump is on low the heater will not turn on unless i put the pump on high and set it back to low, also in the low position the heater pump very hot water into the pool, can this be an issue with the SWG? can it damage the cell in any way?
    When the pump is on high i think i need to open the bypass valve to the heater because the flow is too high.
    Our Build 2016 14.5' x 26' IG Pebble, 14.5K Gal. 3.5' - 6.5' deep, 5 returns, 2 Skimmers, Hayward VS pump, Hayward 525 Cartridge Filter, Hayward E-Command 4, Heliocol Solar, Hayward LED Light, Paramount Ultraviolet, Polaris 280, AquaRite Pro, T-CELL-15, Sense and Dispense (HL-CHEM), Ph Dispense System (AQL-CHEM3) , Taylor K-2006 with SpeedStir
    Feb 2014
    Upstate, NY
    390
    Re: 2 speed pump + heater
    Heaters need a certain amount of water pressure to operate. I take it your heater will still function on the low speed pump setting. IMHO I would use the high speed setting.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    mas985's Avatar
    Pleasanton, CA
    11,742
    It is normal for the temperature rise to increase with lower flow rates but you shouldn't be getting more than about a 8 degree rise on low speed.
    But from an efficiency standpoint, high speed is better.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    On a two speed pump you have to have the pump on the high speed in order for the heater to fire. The pumps usually do not push enough water on low speed. And yes you might have to bypass some of the water because of the pump speed.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    ps0303's Avatar
    Jul 2011
    FL
    3,710
    I see you have two threads on this topic?
    Topics merged. JasonLion
    Paul
