Results 1 to 17 of 17
Thread: brown "dust" on pool bottom
    Aug 2013
    North Kingstown, RI
    28
    I have brown "dust" thats all over the pool floor and in the corners of my pool. Its not slimy, it can be swept away very easily then settles to the bottom again. Im thinking this cannot possibly be algae as the water is clear and I've maintained my chlorine diligently. I have not had CC in weeks. Could this possibly be pollen? I have many trees in my yard-large oaks/pines and who knows what else. I have a Taylor 2006 kit and these are my results.
    Ch 3.5
    CC 0
    Ph 7.6
    Alk 40
    CYA 30
    36,000 IG
    vinyl liner
    DE filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: brown "dust" on pool bottom
    Could always be pollen. Is this immediately following a rain or higher winds.
    Aug 2013
    North Kingstown, RI
    28
    Not particularly. Its been breezy but no high winds yet- arthur is on his way. I just noticed this over the last few days. Am i correct that this cannot possibly be algae ?
    36,000 IG
    vinyl liner
    DE filter
    Aug 2013
    North Kingstown, RI
    28
    Does pollen just vacuum up?
    36,000 IG
    vinyl liner
    DE filter
    Apr 2010
    East Texas
    9,552
    Depends on if your particular vacuum will get it or not. Also, you CAN have algae with NO CC quite easily.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Look at the patio furniture and windowsills and dark colored cars. If they're covered with dust and pollen , so is your pool.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Check your ladders, lights and stairs. I also had no CCs nor any visible signs of algae, just a light dust on my floor every few days. Pulled the ladder, no algae on the outside, but the inside was chocked full, cleaned it using a 50/50 bleach water solution and the "dust" went away.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Aug 2013
    North Kingstown, RI
    28
    How do I know if its algae or pollen? I haven't noticed a whole lot of pollen covering the patio furniture now that you mention it.
    36,000 IG
    vinyl liner
    DE filter
    Aug 2013
    North Kingstown, RI
    28
    Im just confused. I thought I had a handle on this pool chemical thing. I thought you couldn't get algae if you kept FC within target range? When I opened my pool I had a CYA at 0- how does that happen? When I closed my pool it was very high.(like over 150) Where did it go? Someone mentioned soil bacteria and ammonia? My pool sparkled last week. What happened? Im going to clean my ladders like pepsiholic recommended. This happened last year and I almost lost it!
    36,000 IG
    vinyl liner
    DE filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Some pools get the CYA to ammonia conversion, and I think some pools lose CYA due to water displacement over the winter if they had a lot of heavy snow. When you open the pool for the summer you should let the water circulate for an hour before testing. Uncirculated water can also give false test results. Run an overnight chlorine loss test to see if you need to slam the pool. Cleaning the ladder is also a good idea.
    Love TFP? Become a
    TFP Supporter!
    Apr 2010
    East Texas
    9,552
    Unfortunately, it is still possible to get an algae bloom on rare ocassions even with your FC in range. The cya test is only accurate to within +/- 10 points either way. Target your minimum for 1 point FC higher perhaps from your cya reading.
    Aug 2013
    North Kingstown, RI
    28
    I would need to slam the pool with a CC of 0? My CC has maintained 0 since I SLAMMED and did the OCLT a month ago. Actually it may have been 0.2 1 time. I test everyday and maintain my CL diligently. I may need to SLAM the pool again? I will do whatever the recommendation is but Im just very confused right now. I want to understand whats going on.
    36,000 IG
    vinyl liner
    DE filter
    Aug 2013
    North Kingstown, RI
    28
    Hurricane Arthur is over RI right now, we are to expect 3 inches of rain. I think Ill take the ladders off-clean them, brush the pool, add clarifier(this dust seems very light/hard to vacuum) and start from scratch. I'll backwash this dusty substance to waste, then test and add the appropriate chemicals. Ill probably SLAM the pool. Does this sound like a plan?
    36,000 IG
    vinyl liner
    DE filter
    Jul 2009
    Houston, Texas
    9,376
    The OCLT will tell you if you need to slam or not. If the FC holds within 1ppm overnight then you do not need to slam. Go ahead and check the CYA level again just to confirm it is at 30 ppm.
    Love TFP? Become a
    TFP Supporter!
    Aug 2013
    North Kingstown, RI
    28
    Is it possible to lose FC overnight and maintain CC at 0? If so then where does the FC go?
    36,000 IG
    vinyl liner
    DE filter
    Jul 2009
    Houston, Texas
    9,376
    Yes, CC is constantly created and broken down. That's why .5 CC is not considered a problem. It is possible to test 0 CC and half an hour later test with .5 CC and a little while after that have 0 CC again. CC is the waste product of chlorine consumption. When CC levels are higher they take longer to break down and you see the side effects of "chlorine smell" and itching, burning eyes.
    Love TFP? Become a
    TFP Supporter!
    Uhblackhawkmtp's Avatar
    Jun 2014
    Solomon, ks
    49
    I have a similar situation. My observation and comment is, I live in farm country. They're cutting wheat, working ground and replanting right across the road. I attribute some of my dust to that. Also, before I started adjusting to the TFP method I heavily treated with dichloro granules. When I dump my polaris bag, there seems to be a white-ish and gray sediment. Since I stopped using granule and just treat with BBB. I'm getting less waste off of the bottom. I snorkled my vac hose around today. Mixed results, worked ok in the shallow end but I'm too buoyant to stay on the bottom of deep end.
    Pool is cloudy but clearing. I'll check my ladder tomorrow.
    Mark A. Shaw
    40K, IG, Vinyl, DE, Purex Triton Challenger 1 hp 75 gpm, PT Nautilus FNS 60, Polaris PB4-60, w/P360, Test Kit: TF-100 & Aqua Chek strips, Blue elec. pool cover, 16.5 gal Kegerator
