Thread: going on vacation
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    going on vacation
    Any tips on preparing a pool for a few days of no maintenance? I don't have a timer yet and I don't want it to run the whole time I am gone. It will only be off for three days. Can I just clean it really good before I leave and boost the FC to SLAM levels?
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    38,290
    Re: going on vacation
    That sounds like about all you can do. Not circulating for 3 days is certainly not ideal and could result in low FC spots in the pool.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I notice from your sig that you have a 2 speed pump. Why not just leave it circulating on low speed. I think if you boosted to shock level AND kept up circulation, it would work for you. But as Jason above said, no circulation is taking a risk.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Honestly, my concern is what if a hose bursts or comes loose and I burn out the pump? Not sure how likely this is. Just don't like the idea of running it that long with someone checking on it.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I was out of town for 5 days with the pump shut off and the pool uncovered. I raised my pool to mustard shock level, let it circulate for an hour and then turned everything off. It was after 7 pm when we got home and unloaded the car, so I didn't test until the next day. I still had .5 FC in the water. Bumped FC to normal target level and all is good. I just need to get in there and vacuum.image.jpg
    Love TFP? Become a
    TFP Supporter!
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Thanks, Zea3. I still have a couple of weeks to decide pump or no pump. Good to know it can be done.
