Results 1 to 7 of 7
Thread: Floundering
    Jun 2014
    Virginia Beach
    3
    Floundering
    New Member here! Happy to be aboard. 3rd year with this pool, year 1 fine, year 2 floundered, 3rd attempt, drained pool and started again. Received my TFTest kit and used Pool Calculator to add chemicals. Added chlorine 10% HomeDepot, powdered CYA (in stocking), Calcium & Borax. 24 hours later (and one tropical storm), zero chlorine. Help!
    13,500 gal. AG-Vinyl - Sparco Sand Filter- Pool/Filter age ??, Hayward Power Pro 1.5 hp 1 yr.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Floundering
    Welcome to the forum. Please post a full set of test results. BUT.......get your FC up to 3 or 4 with bleach now.
    Jun 2014
    Virginia Beach
    3
    Re: Floundering
    Thanks! FC -0, Cal - 200, Alk 100, PH 7.4, CYA 40.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Floundering
    Is the CYA result a measured result or calculated. I'm just confused on the timeline. If you added your CYA yesterday, then added Chlorine, and then no chlorine added for next 24 hours, you could very well have 0 FC, as the CYA may not be dissolved. At peak noontime sun you would lose about 50% of your chlorine per hour (taken from one chem geek's posts). So after ifyour FC level was 10, 1 hour you have 5 ppm remaining, after another hour, less than 3. So it doesn't take long to lose it with no CYA.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Floundering
    You will need to test and maintain your FC daily. UV burns off teh FC, which is what I belive is happening.
    http://www.troublefreepool.com/conte...mmended-levels
    Divin Dave,
    Jun 2014
    Virginia Beach
    3
    Re: Floundering
    I have added 128 oz. of HD chlorine (11% available chlorine) and will retest in an hour. I brought this pool back from only a few inches of water (had algae & debris) removed as much as possible & refilled. Slammed pool and added about 10 oz. of Cya, I had left over. Waited for testing kit. Tested - 0 CYA at that time. Used pool calculator - added chlorine, massive amount of cya in stocking, calcium and borax, as advised. Chlorine has been added daily. Added nothing for 24-36 hours, after Arthur passed, I tested this a.m......(lot's of uv yesterday, none this a.m.) that's when I got 0 on my chlorine reading. I used the cya test kit to find my reading on it. Thanks Everyone!
    I just recalculate and found I overdid the chlorine (panicked) but the UV's are pumping here so perhaps it will burn off....Also, it indicates I need to add more Calcium. As this is a new addition and in powder form, should I wait a few days before actually adding that?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Floundering
    Quote Originally Posted by mermare View Post
    You don't need Calcium for a vinyl pool. There's no plaster to damage.
