Results 1 to 7 of 7
Thread: Gray Skimmer Trim Fading at Water Line
    Please help me determine the reason my gray skimmer trim is fading at the water line. This is our first pool season.
    Pool Chemistry as of this morning
    PH (Taylor k-1000) = 8.2
    Chlorine (Taylor k-1000) = na
    Total Alkalinity = 110
    Calcium Hardness = 130
    CYA (stabilizer) = 40
    Free Chlorine = 2.5
    Combined Chlorine = 0.0
    Total Chlorine = 2.5
    Salt = ok
    Temp = 84 degrees F
    20 x 44.5 single roman end, ~33,000 gallons, 10 feet deep, garrett vinyl liner, Hayward SwimClear Cartridge Filter, Hayward 2 HP Pump, Cirrcupool RJ60 SWG, Hayward 140k BTU Heater, Polaris 380 with Booster Pump
    20x44.5 (3.5 feet SE, 10 feet DE), IG, Vinyl, Hayward Cartridge (C4030), 2HP Hayward Super Pump (SP2615X20), 2 main drains, 5 returns, Hayward ColorLogic 4.0, Circu Pool RJ60 SWG, Hayward Heat Pro 140K BTU, Polaris 380, Polaris Booster Pump (PB4-60),
    Re: Gray Skimmer Trim Fading at Water Line
    A photo would be a big help. Also, what is the trim made of (plastic, tile, metal, etc)?
    By the by, your PH is too high.
    The trim is made by Hayward. Gray plastic...the site will not let me post a pic.
    Why does my PH keep climbing up?
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Quote Originally Posted by Drsafety View Post
    You need to follow this tutorial on how to upload pictures.
    pH naturally increases when the pool is in use. Plug your numbers into PoolMath and add muriatic acid accordingly.
    Mar 2007
    San Rafael, CA USA
    12,082
    The pH climbs faster when the TA is higher and yours is quite a bit higher than recommended for an SWG pool. See Recommended Levels and Water Balance for SWGs. If you want to lower your TA more quickly than just adding acid to lower the pH, see how to Lower Total Alkalinity.
    Thank you all for the information. I will review the links...
