Thread: FC/CC test issues
    Jun 2014
    Houston, TX
    12
    FC/CC test issues
    Trying to run my tests again with the TF100 kit. First issue: run the FC test, it takes 17 drops to make the color disappear but the solution looks somewhat cloudy, write down the number, turn to the CC test, whoops, the solution is no longer clear but slightly pink! What gives? Note, I cannot stir the solution while writing down the number.
    10000 gallon in-ground, kidney-shaped, plaster pool built in 1965. Original Nautilus NS-24 fDE filter, replacement Hayward RS 750 pump. Located in Houston, TX
    Re: FC/CC test issues
    You took too long doing the test. You need to move along fairly quickly to avoid things like this happening. The solution will always turn pink again if you leave it sitting too long.
    Jun 2014
    Houston, TX
    12
    Guess I'll have to get my wife involved. I don't think it took me more than 30 sec. to write the number down.
    Jun 2014
    Houston, TX
    12
    Update: Reran the test with my wife's help. FC 8.5, CC 0
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You might also want to consider investing in a speed stir, they do make things much easier
    http://tftestkits.net/SpeedStir-Magn...irrer-p56.html
    jmcdtucson's Avatar
    Jun 2014
    317
    Yes, speed stir makes this so easy.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
