Thread: cc calculation ?
    Jul 2014
    Hudson, wi
    81
    cc calculation ?
    I am following the directions on my tf100 kit and it seems the most accurate reading I can get is down to .5. How are others testing to .2 or less? I see others with readings of .2 & .6, not sure how they get those. Thx
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: cc calculation ?
    Use 25 ml sample instead of 10 ml and each drop counts as .2. Everything else stays the same.
    Unless you have a commercial pool there is no point in testing by 0.2s. The additional precision is not useful and it uses up reagents more quickly.
