Thread: pH
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    Ok not sure if this is correct or not, but I am getting worried. Yesterday my pH was at 7.4ish I just tested with the Aqua Chem and its saying it's 8.2 I just raised the CL level and right now it's reading 20ppm. Should I add any muratic acid to try to bring it in the 7.5 range? TA was 100 CYA I am not testing until Sunday, since I added CYA.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Butterfly's Avatar
    South Carolina
    Re: pH
    High FC (above 10ppm or so) gives false high pH readings.
    I would wait and retest after the FC comes down below 10ppm.
    You're done SLAMing when:
