Thread: Leslie Pools Star Shock
    May 2014
    Trenton, NJ
    24
    Hello, ever since having my pool installed and finding this site, I've been using Walmart bleach (8.25%) for chlorination. When I went to Leslie Pools the other day (for a small container of dry acid) I saw they have liquid chlorine. For $8 you got 2 gallons (256 ounces) of Star Shock, which is 12.5% sodium hypochlorite. I'm just wondering if there are any negatives to using this instead of bleach. I am basically questioning it because it is referred to as a shock and not liquid chlorine....however I think it's the sane thing, just marketed under different name. Thanks for the help.
    15'x26' above ground pool installed on 5/10/14, 1 hp -Hayward pro series sand filter (Model # S166T92STL), Hayward Vari-Flow valve (Model # SP0714T1), Hayward Power-Flo Matrix pump (Model # SP1592TLFP). TF100 test kit. Diver Dave automatic vacuum.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,212
    Re: Leslie Pools Star Shock
    Yup, same stuff. You can use it.
    HERE is ChemGeek's explanation/cost comparison.
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    sounds like a good deal to me. No reason not to use it.
    You're right. Its the same thing as bleach with a higher concentration of sodium hypochlorite.
    Quote Originally Posted by Ktooch11 View Post
    Divin Dave,
