Thread: Startup on Intex SWG pool
    jmcdtucson's Avatar
    Jun 2014
    317
    I've just started up my new pool.
    Here are my readings. I didn't measure CYA since I just added a few days ago. These readings are from a TFT100 test kit.
    The chlorine seems low.
    I've put the SWG on boost, but should I just add Bleach?
    Copper 0.1
    PH 7.2
    FC 1
    CC 1
    TC 1
    TA 140
    Salt 4000
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Casey's Avatar
    SW PA
    10,438
    Re: Startup on Intex SWG pool
    If you truly have 1CC, then you should SLAM the pool by manually adding liquid chlorine to your SLAM level based on your CYA., or however much you added.
    jmcdtucson's Avatar
    Jun 2014
    317
    Weird thing is the basic TFT test kit indicates TC of 3-5.
    I'll test again tomorrow and decide, thanks.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    jmcdtucson's Avatar
    Jun 2014
    317
    I ran the SWG boost cycle (before I read on this site that I shouldn't).
    Anyway, new readings based on TF100 drop test:
    FC: 8.5
    CC: 0.5
    PH: 7.2
    It's still too soon to test for CYA because I added it Tuesday/Wednesday.
    Should I just run the SWG for my target CYA (70) and let the FC drift down on its own and keep testing? Edit - sounds like I should do OCLT but my CC is fine. My water is beautiful, I doubt there is anything growing in it. Based on OCLT and my CC and water appearance, probably don't need the full SLAM.
    Sounds like FC 8.5 is fine to swim in. This site is a wealth of information.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    jmcdtucson's Avatar
    Jun 2014
    317
    This evening:
    FC: 5
    CC: 0.5
    FCL test tonight then probably running the SWG like normal in the morning.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    jmcdtucson's Avatar
    Jun 2014
    317
    And this morning. Looks good to me:
    FC: 4.5
    CC: 0.5
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
