Thread: Best Time To Test Water
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    when testing your water everyday for FC & PH until you get to know your pool, should it be done with the pump running, or off, morning or evening? MY pool is nice and clear, thanks to this site.....
    Thank you
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Jul 2013
    Southern Delaware
    71
    Re: Best Time To Test Water
    I always test in the evening. Make sure pump has been running for at least 1/2 an hour so the water is well mixed.
    I get water from about 12 inches down in the water.
    I add bleach in the evening after my testing, just so the chlorine doesn't have to compete with the sun...
    13500 Gal. Above Ground. Vinyl. Hayward E-100 Highrate Sand Filter with Hayward Power Flow LX pump. Installed 2006.
