Results 1 to 12 of 12
Thread: Intex 633t cartridge pump connected to sand filter
    My first post!
    I had a walmart intex sand filter and pump (bought from Walmart) for my previous 18' round intex pool. When that pool liner wore out I tried in vain to patch it. It came to the point where patching was a full time job and the pool still leaked. I gave up and bought the intex 26' round on sale at the end of last season at Walmart. I could not believe how much bigger the new pool was than my 18'. Since I had a sand filter I did not even bother to inbox the intex 633T cartridge filter that came with the pool. Over the last few weeks my pump started making noise. I was slamming my pool (thank trouble free pools) and pump was on 24 hrs. It got louder and louder. Couple of nights ago I was listening to it while trying to sleep wondering what the neighbors thought about it. The next day I took it apart and replaced the bearings. I thought it would be easy but somehow in the process I shorted the coils😢.
    I did not want to go back to the cartridge filter that came with it. I loved the sand filter. Then I got the idea of hooking up the new intex 633T that came with the pool (without cartridge in it) to the remaining sand filter from the old intex sand filter pump. I turned it on expecting a problem, but... It works. The water is being circulated better than before. Even allows me to sweep the pool better than before.
    Question: has anyone else done this?
    Does it shorten the lifespan of the cartridge filter motor to hook it up to a sand filter?
    Any other thoughts of possible problems?
    Would there be any advantage to putting a cartridge into it?
    Thanks
    Wade
    Intex 26' round AG
    17402 gallons, Intex sand filter connected to
    intex 633T cartridge filter (w/o cartridge)
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex 633t cartridge pump connected to sand filter
    The 633T is a surprisingly strong pump for what it is.
    Bearings on those are easy to replace, 608ZZ skate bearings.
    No advantage to putting the cart in the canister. Your sand will do the job with much less hassle.
    Jun 2014
    Houston
    30
    What is the horse-power specs for the T633. I have one and have been wondering. I have not found the answer yet. Being a 2500 gph pump, it is much-much stronger than the T635 1500 gph pump that came with my pool. The T635 also has a awful history of breaking quickly as mine did. thus I have the T633 and love it. Now I know I can hook it up to a sand filter too! Awesome! What kind of sand filter do you use with your T633 by the way?
    6,618 gallon above ground Intex Easy Set model 10320 inflatable ring 18' X 48" rubber pool.
    Intex model T633 2,500 GPH single speed 1/2 hp filter pump.
    Rinz-N-Reuz Replacement Filter.
    Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O.
    Quote Originally Posted by Hermskii View Post
    I have it connected to the small intex sand filter canister model sf15110
    The canister originally came with sand canister and matching pump from walmart, but the 633T is running circles around the pump it came with. And is so much quieter. If I had known this I'd have done it months ago. However I had wrongly assumed the pump that came with the sand filter would have been the better of the two and reasoned the 633T would be a step down. Now it's looking like an upgrade.
    Wade
    Intex 26' round AG
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    The 633T is just shy of 1/2hp. 325 watts current draw.
    The wet end is different between the pump used on the sand filters and the 633T or 635T.
    Sorry, should have done this earlier......
    Welcome to TFP!
    Jun 2014
    Houston
    30
    Thanks folks! All of this is good to know!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    One more thing: the current draw and thus the hp rating of small induction motors like these can and does change according to the load placed on them. It is entirely possible that the same winding and armature section is used in the sand filter pump and the 633T, with different end plates.
    I don't have a sand filter pump to take apart to check this, so I may be wrong. However, the pics I've seen here and elsewhere seem to indicate this.
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    my intex sand filter that came with my 18X52 pool went bad and i had purchased the 633T for half of what the intex sand filter would have cost and am very pleased with its performance. i read alot of reviews on amazon and decided to give it a shot. glad i did although i miss the sand filter when backwashing. might try hooking this up to the sand filter cannister myself!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    WOW!!! IT WORKS!!! and i do believe i have better flow! just backwashed and its great. i'm always amazed at what other people on this forum find that works and as a team everyone here helps everybody else to solve their issues by sharing info. this is a great site!!!
    May 2014
    United States
    9
    Hey guys, sorry to ressurect this thread but where would the pump go? before or after the sand filter. I would think if it is before the filter then all of the junk would go through the pump with filtration and clog it up. So it must go after the sand filter. Correct?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Pumps draw water from the front, they don't suck water from the back.. Pump before the filter.
    Apr 2015
    glendale NY
    3
    I have the Intex Sand & Salt water system model #CS20110, but due to lack of space I never hooked it up, I canned the idea and bought the 633T pump as the 635T pump burnt out after 2 summers. I have had continuous cloudy water problems which is why I bought the S&S water system in the first place. I love the idea of adding the sand filter to it, but do not know how to modify it, can you post an image of how you use both the 633T & the sand filter?
    Intex ultra frame 9" x 18" x52
